Before You Buy Any More Grillcloth for $20
Before you pay too much for chevron grill cloth on " that other forum"----
http://www.radiodaze.com/product/12906.aspx
Looks like great news Phlog!Icon_clapIcon_clap
Jerry
If they actually have it available it sure beats the Fabricland specials that Foggy is trying to pass off on fleabay and repro grille cloth, it's hideous upholstery and drapery cloth that doesn't even look close.
I was also referring to this somewhat more expensive listing:
http://www.antiqueradios.com/forums/view...5&t=222247
Icon_thumbup Icon_clap Great news Phlog, thanks for the heads up!
And, yes, I bought some of the "somewhat more expensive" cloth from "that other forum." Icon_lol Icon_eh I'm getting a 200X later this week with shredded cloth, so I needed some of that cloth.
The Radio Daze ad says "Pre-Order Status - Product will ship in 6 weeks." So it isn't actually back yet, but it's in the pipeline.
This plus the proper decals now too, way to go Daze!
At least some is starting to show up now!Icon_razz
I hope someone brings back some of the other types of cloth, like the kind used in RCA sets, that's actually useful for Canadian G.E stuff too, but it's a very good start since the chevron grill cloth is such an integral feature of so many Philco models
There are currently 7358 online users. [Complete List]
» 1 Member(s) | 7357 Guest(s)
