Can't leave well enough alone-48-482
Threads: 113
City: The Villages
I guess I should know better by now.
My 48-482 just didn't sound good on FM and didn't pull in many stations so I thought I'd go over the alignment again, now that my good sig gen is working.
Bad mistake. As I went to adjust one of the cans (C403) as soon as I touched it I lost my tone and the set went michrophonic. If I tapped it it would work briefly.
OK, so I removed it and opened it up. I tested the mica cap inside and it was within specs. I checked the trimmer and couldn't see anything so I gave it a quick spray with Deoxit and reassembled it and reinstalled it. Nothing!
I managed to get the cover off while it was still connected and when I touch the top of the IF transformer (the ceramic part), I get a tone. if I put a screwdriver to the bad trimmer and touch the blade I get a tone.
What did I do now and how can I fix it?
Eric
The Villages, FL
Threads: 12
City: Minneapolis, MN
You made sure that C403 tested continuous, right? I'll assume you did, and it's okay.
I recently tried going through the whole FM alignment procedure in the Philco manual (with some proper supervision), and was fairly successful.
Ground the plate of the FM1000, make the loading network as described in the instructions, and then, after hooking your generator up to L501B (middle coil under the tuning cap) & setting it to 9.1 MHz, clip the loading network to the top padder of C403b and ground, and then adjust the trimmer fro C403c. You're neutralizing the adjacent coil with that loading network & that will enable you to zero right in on the 9.1 Mhz modulated tone.
Do that across all the IF cans and see what you get.
Threads: 12
Hold off on adjusting the FM detector (C300b & TC300) for now. Just get the IF chain lined up well.
Threads: 113
City: The Villages
My problem isn't alignment, it's C403 as I stated in my post.
Thanks
Eric
The Villages, FL
Threads: 12
Okay, back to my first point. Did you test the continuity of C403?
Threads: 563
I may not understand something, but: how does a cap test continuous?
Threads: 12
My mistake. it's the cap that trims Z503.
Possibly there's intermittent contact in that trimmer, or maybe between the pins and the socket of the 7H7 tube next to it.
Threads: 12
Threads: 113
City: The Villages
OK, so here's where I'm at now: I have a 2nd 48-482. I took the IF transformer out and installed it in the first one. With my signal generator connected and set to 9.1Mhz, If I touch the same trimmer on the replacement I get a tone if the screwdriver is touching it. When I remove the screwdriver, no tone.
By the way both have continuity.
Any thoughts?
Eric
The Villages, FL
Threads: 563
Eric
Make sure you are using non-conductive screwdriver/socket. (Also when adjusting magnetics - non-ferrous or better yet - plastic ones).
Threads: 18
If you don't have the proper tools, you can file down a chopstick to the right size. If you cut too much or wear the D**n thing out, snip the off the problem and file file again.
Threads: 113
City: The Villages
I have the correct tools. I think I'm having trouble getting my point across, sorry. The problem is: with the sig gen connected per the alignment instructions I get no tone. If I adjust it with the diddle stick I get no sound. If I touch a screwdriver to the trimmer in Z403 I get a tone.
Eric
The Villages, FL
(This post was last modified: 05-17-2013, 01:49 PM by Eric Adams.)
Threads: 563
Eric
It is hard to get the point as if you touch a trimmer cap (without pressing) with an insulated took nothing should be happening at all.
Now here's a guess: when you touching it you do fix some cold soldering spot which developed long time ago and you triggered it when first touched the cap.
Take a soldering iron.
Turn the radio fully off / unplug it from the AC.
And touch up with a goodly portion of a rosin flux EVERY contact around that can be possibly flexed when you touch the C404.
All of them - coils and caps.
Then tell us the result.
Threads: 113
City: The Villages
You almost got it. What I meant was that if I touch it with an insulated tool nothing happens. If I touch it with a metal screw driver, I get a tone. Am I still looking for a cold solder joint?
Eric
The Villages, FL
Threads: 14
City: Irvington, NY
Sounds like the metal screwdriver is acting like an antenna and picking up the signal from the generator or a previous stage. Where are you connecting the signal generator?
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM |
Make sure th eperson who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM |
I would disregard everything that is there now. I do not know who and when changed it.
1. Make sure that what you thi...morzh — 12:36 PM |
Model 27-84 BUZZ?Humm?
Depends on the type of hum. SOme is made by outside devices.
Try installing an X-cap (0.2-0.5uF) across the AC line, ...morzh — 12:23 PM |
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance acro...bluecap — 11:01 AM |
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
There are currently 2881 online users. [Complete List] » 3 Member(s) | 2878 Guest(s)
