philco 50-1718 help
hello,
i acquired a philco 50-1718. it is missing its speaker.
can anyone tell me if the impediance is 4 ohm or 8 ohm ?
can someone meter their speaker and let me know the dc resistance ?
the online schematics that i have seen do not tell me the impediance.
thanks for anyone 's help. i can be emailed at vinyltocdr@msn.com
thanks
steve
Like I said in your other message, here on the Phorum, 3.2 ohms is the original speaker. A 4 ohm unit will match ok too.
Philco 91 Tuning Condenser
