#3 Chevron Grill Cloth
Has anyone else noticed this?? Could it be really true?
I put in a pre-order...
http://www.radiodaze.com/product/12906.aspx
http://philcoradio.com/phorum/showthread.php?tid=6639
ooh I guess I'd missed that one!! Icon_smile I'm just happy cause my 16B will look original again! :-)
There are currently 9794 online users. [Complete List]
» 2 Member(s) | 9792 Guest(s)
