Threads: 2
City: Santa Fe, NM
My Model 60B came with both B+ electrolytic filter capacitors valued at 4.0 uF @ 600VDC (Aerovox 610M, big aluminum cans, at over five inches long and inch and a half diameter). All the schematics I've seen indicate they should be 8.0uF (Pt.No.7558). May I replace these with a multi-sectional can rated at 10/10uF, or if I can't find that, something like 16/16uF or 20/20uf since capacitors at these rating are easier to find. Or must I avoid a multi-sectional and use only individual capacitors? Radio has an annoying 60cycle hum.
Many thanks.
MD.
Threads: 14
City: Irvington, NY
Why not disconnect the two large filter cap cans but leave them in place for appearance. Then wire in two separate 10 uF electrolytics under the chassis.
You could use a multi-section can, but they are hard to find these days, and a modern one would be much smaller than the original mounting clamps so mounting would be a problem.
Threads: 562
A capacitor is a capacitor....use whatever you can fit and what satisfies the capacitance / voltage requirements.
Personally I prefer also satisfy a very crude rule of a thumb (I use it for myself) that the ripple current should be at least equal to the load current and the working temp should be 105C.
Threads: 271
City: Wilsonville
State, Province, Country: OR
You can restuff the electrolytic cap cans so you retain the look of the radio on both the top and the underside of the chassis. See this thread for some discussion on it (there are more threads on the topic as well if you do a bit of googling). http://philcoradio.com/phorum/showthread.php?tid=6736
Threads: 562
I always restuff the electrolytics. But, to be honest, I hate the procedure. ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) It's like raking leaves in the fall or mowing the grass - I hate both. Still do it.
Keep in mind that those Aerovox 610Ms are NOT electrolytics, they are paper/oil caps and rarely fail.
However, the word "Hyvol" under the Aerovox name on the label is their name for PCB oil. If you clean these out to re-stuff them make sure you wear gloves and be careful. What you get out of the can is hazardous waste!
I just salvaged 5 of these out of the ruins of the Black Hole in Las Alamos last weekend.
Greg
N0WEK
Threads: 271
City: Wilsonville
Welcome to the Phorum Greg and thanks for the heads up on Hyvol as a trade name for PCBs! In case anyone's interested here's a list of other PCB related trade names: http://www.epa.gov/epawaste/hazard/tsd/p...tradenames
On the "truth is stranger than fiction side", Hyvol is now a trade name for shortening and margarine products:
Threads: 562
So...you open the can, you get sprayed, you glow in the dark. Makes it easier to work without a flashlight.
Threads: 42
City: Chicago, IL
It originally used two individual caps and those are a lot easier to find and cheaper than a dual cap. I wouldn't bother trying the restuff those Aerovox. They're not original and there's the PCB hazard.
Threads: 54
The 60 is supposed to use two 8 uf 450 filter caps, I thing they may have been wet electrolytics originally. If you can't find a pair of 8 mf caps, use 10 mf caps, or 16's, or 22's, 4 uf is too low.
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 10432 online users. [Complete List] » 2 Member(s) | 10430 Guest(s)
