Dial for RCA 9k2
Hi all
Well here goes. Mark connot find any material to make dials, Icon_sad so I will take a long shot and ask, "anyone out there have a dial for a RCA 9k2?".Icon_think I think a dial from a 9K3 is the same. If so let me know.
You might contact Mark Oppat, in Plymouth, Michigan. He bought the stock of new dial scales that Clint Blais had made. There were some of the RCA scales from that 1937 model year.
Hi Doug
That is the person "mark" I refered to in my post. He does not have any and Cannot get the material to make any more. Thanks for the reply tho.
Joe
There are currently 9128 online users. [Complete List]
» 5 Member(s) | 9123 Guest(s)
AvatarAvatarAvatarAvatar
