  • 1 Vote(s) - 5 Average
Another Zenith 9-S-262 thread
The OP found a chairside cabinet, now this one is for sale.
http://antiqueradios.com/forums/viewtopi...5&t=222753
Yep, picked up a 9S244 chairside cabinet. It uses the exact same chassis as the 9S262. The second cabinet in this thread was sold at Kutztown and the first one is available as shown in the link Ron posted. This will be my first chairside and I have the perfect spot for it set aside in the living room. Icon_smile
[Image: http://i863.photobucket.com/albums/ab191...inet-2.jpg]
Larry
