The Magnetic Tuning Off-On switch has a habit of going bad, where it will turn the AFC circuitry (Magnetic Tuning) off and on, but will not turn the lamps off and on. If cleaning does not help, a new switch is the only cure.
Are the two bottom dial lamps supposed to illuminate those pre-sets? I don't see how the top lamp couldIcon_wave
Yes, but they don't illuminate them really well.
Think I'll just manually tune it.
There even dimmer if you buy a replacement dial they don't have the slot around them.
There are currently 3221 online users. [Complete List]
» 1 Member(s) | 3220 Guest(s)
