Looking for some details...
Anyone have any idea what year this Philco would be?
Hi
Can you look on the back and see if you can find any numbers? The model number should start with a letter followed by three or four numbers (most likely four).
Let us know, and we can go from there. Thanks.
I have asked the seller for more info, but unfortunately have not heard back yet. Was hoping to figure out a bit more about it before I drove out to see it.
Sorry, thought this was your set already.
Rough guess: 1964-1974, and probably closer to the latter than the former.
Philco 91 Tuning Condenser
