38-12 antenna coil
Finally had a chance to play with the 38-12 for a bit and ended up winding some #34 wire on the open oscillator coil I had and fired up the set. While that seems to work fine , the primary on the antenna coil is open. As luck would have it, the junker set has a bad one too (remind me why I bought the junker set). Has anyone used the universal antenna coil that AES sells? I tried finding the break without luck and there are far too many turns for me to want to even attempt to rewind it Icon_mad
Hi Tony,
I have used a universal coil on a Dumont 'picture frame" set a few months ago. It had been robbed from the chassis when I bought the set.
I replaced the 4 termonal coil to the board and it worked just fine.
On your diagram
http://www.nostalgiaair.org/PagesByModel...013236.pdf
I see another short coil above the RF coil. Maybe this is part of the original? Or maybe a seperate coil that is on the antenna loop?
Just make sure you ID the leads on the replacement fefore installing.
I see that you tried to find the break in the old coil, good for you. I was able to get lucky a few times and found the break 2 or three turns into the coil. Or found the break right at the terminal. But once you've unwound much of the coil it seems hopless. I have had some that were broke right at the inner side, and rewinding would be out of the question at least for me.
So to your original question, I'd say that the generic replacement would work fine.
Good luck,
Gary.
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
There are currently 1535 online users. [Complete List]
» 1 Member(s) | 1534 Guest(s)
