39-55 chassis
Hi everyone,
I got around to pulling the chassis from my 39-55 and thought I would post some pics. Apart from a lot of dust the chassis is in excellent conditionIcon_clap! Rubber grommets and bushings are still flexible and most of the original rubber coated wires are still in remarkably good shape (as compared to my 40-150)!
The only non original parts I can see are two Aerovox electrolytic caps, all other components seem to be the originals. Also all but two of the tubes are Philco brand. the 80 rectifier is a RCA tube and one other is a Sylvania.
[Image: http://i1160.photobucket.com/albums/q500...95ccd6.jpg]
[Image: http://i1160.photobucket.com/albums/q500...be94da.jpg]
[Image: http://i1160.photobucket.com/albums/q500...ec1d7e.jpg]
[Image: http://i1160.photobucket.com/albums/q500...de59f8.jpg]
[Image: http://i1160.photobucket.com/albums/q500...ae6426.jpg]
[Image: http://i1160.photobucket.com/albums/q500...de7267.jpg]
[Image: http://i1160.photobucket.com/albums/q500...3a76ce.jpg]
Philco 91 Tuning Condenser
