Model 620, resistor failed
Hi;
Was finishing up recaping the 620 when part 49, 20,000 resistor broke. Does any one know what voltage rating it should be and where I might get a replacement. Thanks.
God bless,
Dave
Hi David,
Think you really want to know the wattage not voltage rating. Appears to be a 1 watt resistor based on the physical size in pictorial drawing but go with a 2 watt since it will look better. Closer to the same size of the original.
Richard
Richard:
Thanks, ordered one yesterday from Radio Daze.
There are currently 10562 online users. [Complete List]
» 2 Member(s) | 10560 Guest(s)
