Stromberg Carlson Dial Cord
Anyone know where I can get a dial cord diagram for a Stromberg Carlson 240L. So far I've come up empty.
Eric
I looked at mine, It's belt driven and runs around the knob shaft, through the idler assy. The backside of the belt runs on the idler pulleys then it runs to the top.
Sorry for the lousy pic
Tim
Thanks for the picture
On the road for a few days so I won't be able to do anything till late next week does anybody know where a belt like that can be had?
Eric
Eric
JFD PN = 48
GC PN = 151
http://www.adamsradio.com/ has the "151" belt for $6.50
Best of luck with the 240. I have one here stripped and in pieces. Will be a winter project.
Tim
Tim
Great thanks for the info
What is the "JFD=48"? I see the 151
JFD is a different brand
http://plymouthcolony.net/starcity/radio...albelt.pdf
Thanks just ordered the 151 from Adams will keep you posted
AK
There are currently 9932 online users. [Complete List]
» 3 Member(s) | 9929 Guest(s)
