80 Jr Troubleshooting- B+ measurements
Mondial,
Re: checking B+
My line voltage was at 109v from the isolation transformer so I made another set of measurements with full line voltage at 120v.  Bias across the 325ohm resistor is 16v.  Getting 328 ac volts per plate on the 80 rectifier whereas I was only getting 300 before.
[Image: https://www.dropbox.com/s/nwmo4vfobvyzwi....jpg?raw=1]
Does sound better and getting a number of stations at this point. Thanks!
There are currently 5402 online users. [Complete List]
» 1 Member(s) | 5401 Guest(s)
