Chassis & Cabinet Model ID?
Threads: 27
City: Rochester, NY
Hi Greg,
Welcome
Go to the home page, then under knowledge base there is a guide that will help you Id your set.
Tim
Threads: 12
City: Palm Springs, CA.
Threads: 54
I think it's a model 660 chassis, what Radiobar called it I have no idea. Most of these came with a 620 chassis so this one is better then average.
Threads: 12
Thanks Arran,
I know a lot of the Radiobars came with a 610 or a 620. What is the difference between those chassis' and this one if it is a 660?
Best,
Greg
GregL Wrote:What is the difference between those chassis' and this one if it is a 660?
Four more tubes, four bands instead of three, and more weight
Yes, that is either a 660 or 665 chassis. Nice! Not quite a 116, but the chassis is the same size as a 116 and it has the same audio output circuit as a 116B. It will perform much better, and sound better than a 620.
Threads: 12
Well, thanks for clearing that up Ron. The 4 bands you mentioned, are they short wave bands?
Greg
If you notice on your dial scale, it tells what each band is
1 - Long wave - 150-390 kc - not much down here.
2 - Standard Broadcast - The normal AM band.
3 - Police, Amateur, Tropical SW - You'll find some tropical shortwave on the high end of this band (around 5 mc) at night. Police departments have long since abandoned these frequencies in favor of VHF and UHF frequencies.
4 - Shortwave - All of the usual SW bands are crowded into this fourth band on your set.
Threads: 54
In some areas you can pick up beacons on the longwave band though I have heard that you can sometimes pick up longwave stations from Europe from the Eastern end and sometimes the middle of the continent with the right antenna. Other then that if you can pick up anything at all it's usually a navigation beacon. Apparently there is some interest, and some proposals, for using the longwave frequencies for amateur use so it may not be as useless in the future.
Does the lens in front of your dial have a window at the top?
(This post was last modified: 07-22-2013, 10:07 AM by Arran.)
Threads: 12
Thanks for all the input guys. Arran, I don't seem to have any additional window at the top of my lens. What would that indicate?
Greg
Greg
Is this an actual photo of your Radiobar, or does yours just look like this?
[Image: http://philcoradio.com/phorum/attachment.php?aid=2218]
That looks like it has a 610 or 620 chassis inside, smaller escutcheon with no provision for a shadowmeter. A 660 chassis is much larger than a 610 or 620 chassis, and needs a much taller escutcheon with a window at top for the shadowmeter screen. Plus, the shaft spacing of the 660/665 is different from the 610/620, a 660 or 665 chassis would not fit inside a Radiobar made for a 610 or 620 without some cabinet modifications.
Threads: 12
The picture is not of mine. It is of one that looks identical to mine.
Threads: 54
Well the model 620 and 610 do not have a shadowmeter but the model 660 and 665 do have a shadowmeter. The shadowmeter, if still functional, works kind of like a magic eye tube where there is a shadow, viewed through a little window of slot just above the dial, that narrows when the radio is tuned to a station and widens when it isn't. The dial lens should have a clear window right at the top of the oval, if it doesn't then someone swapped a 660 chassis in place of the original 620 chassis. This may or may not be a problem in that the escutcheon and dial for the 660 may have more viewing area then the 620 since it has four bands instead of three, maybe Ron or someone could tell you if the escucheon from a 660 or a 116 would physically be larger too.
The 660/665/116 escutcheons are larger...much larger...than the 610/620 escutcheons. Plus, as I mentioned before, the spacing of the control shafts is different - the bottom three controls are a bit further apart on the 660/665/116 than on the 610/620/630.
Threads: 12
Arran,
I have to amend my reply. It looks like there is a small window above my dial. I didn't really understand what you were asking before but when I looked at my dial I see there is an area above the dial that aligns with a light socket behind, which would illuminate the amber area as seen in the picture below. I assume this is what you were asking about?
Best,
Greg
Gloritone 27 Radio
I have a model 27 that someone painted the cabinet brown. I've been trying to sell it for awhile but the cabinet paint m...Jim Dutridge — 02:30 PM |
Restoring Philco 96
Joseph
Yeah. The situaction is complicated by me living with my family in NJ while mom is in FL.
Were it not for my ...morzh — 10:55 AM |
Restoring Philco 96
Best of wishes for your mother. I hope she recovers well. My mother struggles with sciatic pain as well, so I am familia...jrblasde — 10:41 AM |
Restoring Philco 96
Well, because I am away, I cannot check it. Hope mom becomes better enough for me to get back.
I think I will be here f...morzh — 10:27 AM |
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM |
Gloritone 27 Radio
Hello john,
That, is the first time I have have seen or heard of that brand and model.
Welcome to the party !!
Sincer...radiorich — 08:08 AM |
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM |
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27:
A little bit of extra t...Eliot Ness — 05:48 AM |
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM |
42-345 Resistors
Great comments.
I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM |
