shadow meter
hey guys
i have a philco shadow meter part 6497-y 5053r
any one know what radio it goes to ?
A couple of nice close up pictures may provide you with the information you need.
There were at least a couple different styles and used on many different models.
Jerry
This link may help you in determining what you have.
http://www.philcorepairbench.com/tips/svctip01.htm
There are currently 10390 online users. [Complete List]
» 1 Member(s) | 10389 Guest(s)
