42-1008 code 121
I would like to know if chuck has a schematic for a 42-1008 code 121
Sure. You could have just gone to my site and seen the info there on the Schematic Info page with all the details. I have original paper from 1928 up thru 1947, so your 1942 radio-phono console is certainly in there. Icon_smile
Chuck
And here's the link:
http://www.philcorepairbench.com/schematics.htm
There are currently 9800 online users. [Complete List]
» 3 Member(s) | 9797 Guest(s)
