Bakelite scratch repair
I know this has been discussed before, but I thought I would share something I found that really works.
For scratches in Bakelite I found that Turtle Wax headlight restorer really works. It is a kit that comes with different grades of sanding pads, a cleaner and compound for polishing.
After removing the scratches I polish with car wax and it looks great.
You can get it at any auto parts store.
Eric
The Villages, FL
Thanks for the tip EricIcon_thumbupIcon_thumbupIcon_thumbup
Thanks Eric... My own little secret is for a replacement dial cord. A lot of folks use fishing line, but I've found that waxed thread works even better. If there is a Tandy leather store nearby, they sell it. You can get a huge roll for $10. It never, ever slips, doesn't stretch and it holds a shape for ease in getting around pulleys. It's used in leatherworking, so any leather repair shop will have it.
Thanks, PuhPow, I use the string used in cooking but your idea sounds better because it is waxed. I'll give it a try.
Eric
The Villages, FL
I have used auto paste wax for bakelite cleaning and poloishing, the one step type seems to do well for me.
Pau
I use Excaliber car polish - red and black can.
Chuck
There are currently 7384 online users. [Complete List]
» 1 Member(s) | 7383 Guest(s)
