Threads: 145
City: Elko,MN.
Hi guy's,
Brought an old 630 home and hooked it up to my variac.
All tubes light as well as bulbs.
Has no sound at all, not even hum or static.
Tried swapping a few tubes, but no luck.
Lookes like someone years ago replaced a couple of the electrolitics. Did a messy job of it too.
I replaced those 2 with no change.
Any suggestions on what I should check next?
I am leaning toward output transformer or maybe even speaker?
This looks to be a difficult one to work on. Typical Philco I guess.
murf
Threads: 112
City: Medford OR (OR what?)
Check for high voltage on the + of the first filter cap. That being ok, which by the way, may be exceeding 450 volts and the rating of your replacement cap, move on to the 2nd one. No voltage there = open field coil, if there is voltage on the 2nd cap + report back.
Threads: 145
City: Elko,MN.
Looks like 230 and 240 vdc on the 2 caps.
Checked voltage on the speaker, and checks the same.
City: Kentucky
Any bakelite blocks?
Threads: 145
City: Elko,MN.
It's a Philco.
ANswer your question?
Threads: 9
City: Vieques, PR USA
State, Province, Country: PR
As a friend of mine once said, trying to troubleshoot a radio before recapping is like trying to start a campfire with wet matches.
Threads: 18
City: Mesa, AZ
^^^ Seems strange to me that anyone would still try to use old caps, electrolytics and even resistors, although the values "seem" to be fine, and have "recently" been recapped. (20 years ago, or so). The values can go right out the window, once they're powered up. I recently got onto the habit of changing out the resistors now, when I'm in there. Easier at that point. Might as well, as the results are noticeable, and it's only a matter of time before they'll all go out anyway, if you don't.
Threads: 145
City: Elko,MN.
Would love to have it working before re-capping it.
Very hard to diagnose the problem without some sound.
City: Kentucky
Quote:RE: philco 37-630 no sound
It's a Philco.
It wasn't so much of a question as it was a suggestion. As others have said, recap it, replace resistors. I bet it makes noise then...
(This post was last modified: 09-01-2013, 09:50 PM by Jamie.)
Threads: 112
OK All of the above is good advice. So, the next thing I would check for NO audio output is continuity across the primary of the output transformer. Check the secondary and the speaker voice coil too but these are far less likely to fail.
Replace all of the paper and electrolytic caps.
You could try next to inject a signal on the grid cap of the 75. You can just touch it IF YOU KNOW WHAT YOU ARE TOUCHING. Listen for hum. Don't get electrocuted.
(This post was last modified: 09-01-2013, 10:11 PM by Phlogiston.)
Threads: 14
City: Irvington, NY
Check for B+ voltage on the plate of the 6F6 output tube. If you have voltage on the screen grid pin but not on the plate then the output transformer primary is open.
You should have about 250V on the screen and slightly less maybe 240 or so on the plate.
Threads: 60
City: Kokomo, Indiana
I had the same problem with mine. The output transformer mounted on the speaker was open. Got one from Playthingsofthepast.com for about 8 bucks plus shipping. I troubleshot it by hooking up an old speaker across the contacts of the transformer. Don't remember which two contacts, but you'll figure it out.
For what it's worth, I like to get my sets working if possible before doing a re-cap. I test for sound after each cap R&R. That way I know immediately if I screwed up. Yes, I've had a couple get all smokey on me...but so far, nothing serious or un-fixable happened.
Threads: 55
City: Evanston, IL
Also check to open RF, ant, osc and IF coils. Philco's notorious for corroded copper wire at terminals and/or in the windings themselves.
Chuck
Threads: 27
City: Boulder, Colorado
Hi All;
You could also use a 60 hertz (cycle) tone to find about where your signal is not getting thru..
Take a cap about .01 and tack it to one side of the 6.3 filament winding, and attach a jumper cable or small wire to the other end. And go from the speaker back.. You should get a 60 cycle hum from the speaker as you work your way back toward the front of the radio circuit.. Where it disappears is where you need to start looking for the problem..
THANK YOU Marty
Threads: 145
City: Elko,MN.
Thanks for all the info guy's.
Some of it sounds pretty technical, but it gives me some different avenues to explore.
murf
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
There are currently 2417 online users. [Complete List] » 1 Member(s) | 2416 Guest(s)
