Philco 84 restore
Restoring Model 84, Volume on/off switch is shot. any suggestions on replacement. I've been searching but can't seem to find one. It appears to be a 20k pot with 1.5 inch body and 1 inch shaft, fat flat. thanks
Go to Mark Oppat http://www.oldradioparts.net/index.html He can build you anything. The body of the control really is not important, new one will likely be smaller.
Thank you very much, I'll give them a try.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2303 online users. [Complete List]
» 3 Member(s) | 2300 Guest(s)
