Goes Dead, Philco 45
#46
The 41 should be OK. The voltage you are listing are within the specs of the tube. Can swap the 85 for a 75. The 85 has a bit more gain.
Marty,
Reflow all the solder in the pins of your 41. This can take some patience, as it is sometimes hard to get the old solder to flow. Once it's liquid, add a bit of new solder into the tip of the pin. I reiterate: this does not sound filament related. If it were, the radio sound would drop over a few seconds once the filament opened. This is going out all at once. Since it does not go out with the 42 tube in place, it speaks to the 41 tube. Given this, either the tube is defective internally, or there is a cold solder joint inside one of the pins, where the wires from the envelope connect to the base. If reflowing this solder doesn't help, just toss that 41 and get yourself another one.
#48
Hi All;
Thank You Brenda Ann.. Brenda Ann You have the 41 and the 42 numbers reversed, But, I understand what you are stating.. I will try and Reflow the Pins on the 42 Tube..
Also, it works on the Shortwave Band as well..
It had run now for over an Hour..
THANK YOU Marty
#49
Glad to hear that you seem to have found the problem. Icon_smile
#50
Hi All;
Brenda Ann, No it was Everyone on the Phorum and me who got it working.. THANK YOU to Everyone..
After some cleaning up, it will be back to the Philco 34..
THANK YOU Marty
#51
Hi All;
Its still working..
I found that I have had to lower the input voltage from 110 on the Variac to 100 on the Variac, so that the 41 Tube does not have a slight Purple glow at the top of the Tube..
THANK YOU Marty
#52
Bad Marty, not a good sign. Get a 42.
Jerry
#53
The purple glow isn't any thing to get excited about. Just some electrons hitting the glass on the inside. Now if the plate or screen grid are glowing red now you have a problem!!
Hi All;
The purple glow was a small ring arround the top of the tube and Nothing was glowing red.. So for now I think I am OK..
THANK YOU Marty
#55
Eventually, you really do want to get the proper 42 tube. Although similar to the 42, the 41 has lower power and current capability, and different bias requirements.
#56
Hi All;
I plan on getting another tube, baring that I can and the Creek don't rise.. Along with some spares for this radio.. Sometime next week..
THANK YOU marty
#57
If your are thinking about getting a few spares I say the first tubes to go is the rectifier then the audio output,mixer, and then 1st audio, IF amp.
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3266 online users. [Complete List]
» 3 Member(s) | 3263 Guest(s)
