40-190 chipped veneer
Congrats on the repair! I'm looking forward to the images...
Pic-tures... Pic-tures... Pic-tures... Icon_biggrin
Here are the photos. Again, the repair is certainly not invisible, but the damaged area is certainly less visible to the casual visitor. I might work on it a bit more, but it is certainly an improvement. - Roy
That does blend much more nicely! From the more distant shot, it doesn't draw any attention at all...
There are currently 4287 online users. [Complete List]
» 3 Member(s) | 4284 Guest(s)
