37-116 grill cloth
Ok maybe a dumb question, but in the cutouts for the 2 outer resonators, was the pattern a V centered in the cutouts or \ in the left and / in the right?
Wondering cuz the reproduction cloth is 18" wide and the sounding board is 23 1/2" wide. Seems like if was one piece 24" wide a littler wider reproducton cloth would be nice.
John
Las Vegas, NV USA
I wondered the same thing.. seems like everyone who is carrying this new design only sells 18x25.. I wonder if they make it any wider. seems like a sad oversight on their part. there are plenty of the consoles around needing TLC..
Even the old stuff would not fit the 37-116 unmodified. There are Vs in both of the smaller grills.
There are currently 5585 online users. [Complete List]
» 1 Member(s) | 5584 Guest(s)
