Toner Colors for 37-116
Hi all, Im a first time poster and i am hoping someone can help me out with my 37-116 standard dial. I need the mohawk toner colors for this,especially the top corners and the bottom base. I apologize if this has already been answered somewhere. I did try a search but didnt find anything.
Hi Mark, and welcome!
I would suggest the Ultra Classic version of Medium Walnut (not sure of the correct color name in the Ultra Classic version) for the main body of the cabinet, and Ultra Classic Extra Dark Walnut for the top and bottom trim. The Ultra Classic, being dye based, will allow the grain to show through.
Thanks Ron I appreciate the help very much.
There are currently 6321 online users. [Complete List]
» 1 Member(s) | 6320 Guest(s)
