My Model 44 I'm Working On
I'm trying to do a cosmetic restoration of this set. I am wondering how to refinish the flaking toner from the edges of the top and on the feet. Any ideas?
[Image: http://i97.photobucket.com/albums/l213/u...5be170.jpg]
[Image: http://i97.photobucket.com/albums/l213/u...4dffe0.jpg]
Thanks.
In this case you might want to try the Howards Resto-a-Finish system.
There are currently 5528 online users. [Complete List]
» 2 Member(s) | 5526 Guest(s)
