fada 41-608
hey guys and gals
I have a 41-608 fad radio/record player vm ? no label on it radio recapped works great record player works fine on and off when arm lifted I know cartridge has to be rebuilt but can I put a signal to wires see if the amp part of radio works ?
thanks sam 8)
ps their is no schematic for it
Fada 41-608?!?!? Are you sure that model number is correct?
hey ron I am 99% pos brother in law has cabinet still but I could not find any info and fadatuberadioman has same one he could not find any info either hi have same one as his http://www.youtube.com/watch?v=Oh3UJAVqCQI
sam 8)
There are currently 9738 online users. [Complete List]
» 3 Member(s) | 9735 Guest(s)
