Grill cloth installed into 37-116
Since no one seems to sell grill cloth with the proper width I had to use some of the original cloth in the clarifier area of the cabinet. I tried to align the chevron bars as close as possible and I think I came close.[Image: http://i1281.photobucket.com/albums/a508...604f0b.jpg]The cabinet will only require a final cleaning and then the finished chassis will be installed.
Nice job! That came out great! Way to improvise!
Craig R.
great job let us know how she sings when you get it up and running..
Thanks PhilcoJohn, I will report on the the sound and what song she sings. By the way I see your are from the Hudson Valley, I am originally from Poughkeepsie where are you. I bet the fall colors are great.
That one is a beauty! Nice work so far!
Looks Great!!!
I've got a 116X that I'm going to be doing the same thing on. Someone thought (or not) it would be a dandy the grab the cabinet there. And ripped it all up fortunately the clairifiers are a ok.
Keep up the good work&keep us posted.
I have that same cabinet but I was lucky my clarifier areas are pretty nice.[Image: http://i1281.photobucket.com/albums/a508...70c877.jpg]. I need to pull them out and do a lite cleaning with a paint brush and small shop vac.
Ronnin...Hello my neighbor! I live in Lagrange! Wow small world. The colors are beautiful right now, but half the leaves have fallen. I dont want to think what happens next.
I hate too tell you but you know what comes next, the Hudson valley is notorious for winters that make you want to Cus.
The speaker table error?
Philco 70 antenna lead
