My Next Project - worse than the last?
City: Kentucky
You'll do great. One thing I always tell myself - the worst that can happen is you have to strip it again and start over again. Which is a lot better than screwing up a chassis and ruining some rare part.
City: Kentucky
I got an early start today. Top photo is the cabinet after a date with Mr. Mohawk. I used a light coat of Light Oak/Natural Ultra Classic Toner. I had planned to add some dark walnut to the sides, but I think it looks good now.
As soon as the toner dried, I replaced the original decal... next up, is clear coat, and this cabinet will be finished. 8)
City: Kentucky
From this...
To this...
Final clear coats, some new brass screws, and some brasso.. and she's all ready for the chassis..  .. I am very happy!
(This post was last modified: 10-18-2013, 01:23 PM by Jamie.)
Threads: 69
City: Kansas city, MO.
That looks really great! Good save, I don't think I would have tried a cabinet that far gone. Maybe some day.
Threads: 27
City: Rochester, NY
Beautiful!
Tim
Threads: 72
City: Linn Creek, MO
City: Kentucky
Thanks everyone. It means a lot to read your compliments. Glad you like it.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 88
City: Tacoma
Just amazing. Maybe I'll put getting to your level of artisanship on my bucket list.
Threads: 154
City: Westland, MI
Great job!!! From a sad case at best to "purt near" brand new showroom condition. You should proudly display that set. Take care, Gary.
Threads: 154
City: Westland, MI
Hello everyone, and especially Aaran, When I suggested steaming the cabinet in a pot, I didn't mean cooking it until it was cellulose mush. At no more than 10 minutes steaming, only the thin porous veneer will have the opportunity to absorb any appreciable amount of moisture. It sucks it in like a sponge! The heavier wood components will not have had enough time to moisten anything but their surface. I used this method to repair an antique mahogany jewelry box for a friend that had gotten soaked in a basement flood and stretched apart very similarly to this radio. It worked great. Just another two cents worth. Take care, Gary
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 3272 online users. [Complete List] » 2 Member(s) | 3270 Guest(s)
