Ballast Tube Question..
Hello Puhpow!!! VacuumTubes.Net has 49a ballasts on their price list. Might not hurt to check them out. Price was $12.00. Take care, Gary
Gary, I called them and asked. They took my number and never called back. Thanks for looking for me though. I appreciate it.
There are currently 9787 online users. [Complete List]
» 2 Member(s) | 9785 Guest(s)
