restored 23x pics
restored last year and won first place,peoples choice,and best of show all three awards at once. this set was posted on craigs list on late friday afternoon in dallas, it was at a business ,closed over the weekend and the pics were real bad but enough to figure out with reserch that it was indeed a 23x. monday morning i kept calling until they awsered and it was still there,i was the first caller ill take it . ok they said i asked for address would you beleive i was2 miles away it was at a old recording sudio near downtown dallas, they said it was in storage room, room was being cleared out and the someone was going to restore it long ago and no longer worked there he had left it and there it sat. i can talk more about it later and post better pics of it before and after.if any body cares for me to do that i will. Thanks Fred taylor
For sure Fred
Nice find!
Tim
looks great, good catch!
Stunning! Icon_clap
                Test for larger pictures on 23x
pictures look to big on unrestored 23x, still working on photo bucket to do this. please bare with me on getting good photos of my radios to this site
Fred Taylor
They look fine to me - your picture width is 1024 pixels now, which is a good upper limit. Icon_thumbup
    another test
        test on size of pictures
Philco 91 Tuning Condenser
There are currently 10481 online users. [Complete List]
» 2 Member(s) | 10479 Guest(s)
