Philco B711
Hi folks,
I just got another Philco in my collection a model B711 from 1954.
The problem is it only picks up one station which is 620 KC. It will absolutely need a complete recap.
Hi Pete
Does the clock work? If so...it would be neat to use as it was originally intended, as a bedside radio with alarm clock...
Yep, the clock works.
So have you tried the align the set?? And have you tested the tubes?? Both can give you poor performance.
Nope, I didn't try alignment. Don't have the proper equipment. And I don't even have a tube tester but I did try tubes from another Philco with the same tube lineup.
Philco 91 Tuning Condenser
There are currently 8721 online users. [Complete List]
» 1 Member(s) | 8720 Guest(s)
