Identify this Emerson?
Does anyone know what model this is?
Eric
The Villages, FL
344 from 1940
The marking on the loop antenna (if you look @ the ebay pics, http://www.ebay.com/itm/Vintage-Emerson-...3386feefa7 ) would seem to indicate a 7KW-228 model. If you look at this Worthpoint page: http://www.worthpoint.com/worthopedia/em...deco-table , they show a 7KW-228-2 that looks a little different. I wonder if the 13 on the back of the one on your pic means its a version 13 and thus accounts for the diff Icon_confused:
Here's an ebay.com.au post that has the 7KW-228 although the pictures seem to show only intermittently --- slow electrons from Australia?? http://www.ebay.com.au/itm/1930s-40s-Eme...true&rt=nc
I think you got it, Bob. I thought it might be a DQ398 http://www.radiomuseum.org/r/emerson_dq3...ch_dq.html
It looks like they made quite a few that are almost identical around those years.
Eric
The Villages, FL
Yes, there were lots of them that had a similar style. Even some of their bakelites looked similar: http://radioattic.com/item.htm?radio=0270298
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
