Philco 38-690/Pictures
I Posted some pictures on my first post.
I would love some feed back on what you guys think it is worth?
Ray
Doesn't posts #7 and #13 give you an idea ?
My friend says he will fix radio. I am going to buy it.
Thanks everyone.
Ray
You will enjoy it. Mine sounds terrific. The refinish on that looks great.
Beautiful radio. If you like it, go for it. Life's too short.
Congratulations! Icon_clap Icon_clap Icon_thumbup
Beautiful radio......It is on my wish list...
Philco 91 Tuning Condenser
There are currently 10408 online users. [Complete List]
» 2 Member(s) | 10406 Guest(s)
