Bakelite cleanup
I have a nice little Zenith in a bakelite cabinet, cabinet is solid but has 2 issues.
Paint dots spattered on a good portion of the top, may be oil based. I have removed these before with warm soapy water and a soft brush, not coming off this time. Suggestions?
Also kind of a gummy stuff, adhesive maybe, on a couple of spots, thinking of using Goo Gone. Anyone have any experience with that stuff.
Cabinet is brown bakelite.
Thanks.
Hi Paul,
I've had good luck with paint spots on bakelite with GoJo with pumice. Once you remove the paint go over it with Novus. It should look great.
BTW, thanks for the Cab song!
Eric
The Villages, FL
I will see if I can pick some Gojo up. You are welcome.
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
There are currently 2249 online users. [Complete List]
» 3 Member(s) | 2246 Guest(s)
