Knight Signal Generator Leads
Good morning all
A friend has let me borrow a Knight 650 Signal Generator with no lead(s). At first I thought that the connector on the front of the unit was an SO-239 but upon closer look, it is not. Can someone tell me what kind of connector this is and where can I get one? Also, could I improvise with alligator clips?
http://www.ebay.com/itm/Sure-Microphone-...1257298198
http://www.ebay.com/itm/SCREW-ON-RF-GENE...1146331455
Thank you BrendaAnnD. I learn something in this hobby almost everyday!
There are currently 9862 online users. [Complete List]
» 1 Member(s) | 9861 Guest(s)
