Later style 70 lowboy?
I know from that gallery that the model 70 was offered as a lowboy and it is rare, but I am wondering if a later version was offered? The reason why I as is there is a 70 lowboy available to me from the same place I rescued my 90 lowboy from, but it doesn't match the one in the gallery. The cabinet is more like the 50 or 51 lowboy in looks. It isn't a 70 highboy with the legs cut, I checked that right away. So, is it possible that the 70 was offered a a lowboy cabinet more matched to the 50 and 51 that was offered later on? I should have gotten pictures of it, but I was a man on a mission that day.
There are currently 9842 online users. [Complete List]
» 1 Member(s) | 9841 Guest(s)
