Stromberg-Carlson 225-H
#31
I am not going to fret it too much.
In the long run, the black wedges there create a good pattern to dissipate this missing piece using some sort of black veneer properly installed and lacquered.
There are currently 6623 online users. [Complete List]
» 2 Member(s) | 6621 Guest(s)
