MORE Phonograph Woes
Anyone know where I can go to find a needle cartridge for a 1946 Philco D-10A phonograph? FYI it is mounted in a Philco 46-1209.
If that unit uses a Piezoelectric, Rochelle Salt, crystal cartridge, like my 76A/46-1201, then the cartridge may also be stone cold dead.
West-Tech told me they were very hard to come by.....
You would pretty much have to substitute it with a more modern cartridge, or rebuild the old one, unless it is one of those magnetic types. This is part of the hold up with my Bing Crosby, that and a wonky mercury switch.
I have a 47-1230 D-10A phonograph with Dynamic cartridge. If it takes the same needle, which it sounds like it does, I contacted this ebay seller and he sold me this needle... http://www.ebay.com/itm/Vtg-NOS-Philco-D...0899675089 . He might have another if you want to contact him on ebay. Warren
I clicked the link but was unable to pull it up.
Hmm, lets try this one.. http://www.ebay.com/itm/271292984355?ssP..._262wt_880 This one should work... contact the seller, when I got mine the auction was ended but I contacted him and he said he had more than one and sold me one.
Thanks, I'll give it a try!
No Problem,, I would be interested in knowing how it works out. Icon_e_smile
There are currently 10298 online users. [Complete List]
» 2 Member(s) | 10296 Guest(s)
