Philco 91 Tube Shield
I am looking for a ganged tube shield for a Philco 91. I have seen other tube shields that look like they may work. I was wondering for those that my have seen a model 91 tube shield if you could tell me how many dividers are in the original 91 tube shield. I believe there may be two which would be three compartments but then there could be three dividers which would be four compartments.
Charlie
Hi Charlie,
Here is a picture of the tube shield from the 91 I am working on. it has two dividers as you can see. hope it helps!
Kevin
[Image: http://i1160.photobucket.com/albums/q500...932ffa.jpg]
There are currently 9840 online users. [Complete List]
» 1 Member(s) | 9839 Guest(s)
