Just finished restoring a 49-904
Nice performing little table model AM / Shortwave. The entire front grill / dial cover is one piece of molded clear plastic. Even the dial "needle" is clear plastic. There were 18 caps to be replaced, and some took MacGyver like skills to reach. But the biggest challenge? Getting a dollup of 60 year old pink nail polish off of that fragile clear plastic dial cover! Icon_lol
Very nice
Looks great Greg
Nice case, good swirl. That is a neat looking set, dignified. Nice work old chap.
Philco 91 Tuning Condenser
