Speaker Field Coil Question
Looking to verify the DC Ohms of the Following Speakers
CATHEDRAL MODELS
Model 51 Philco 6 inch Speaker FIELD 2500 DC Ohms ??????
Model 80 Philco 6 Inch Speaker FIELD 1200 DC Ohms ???????
Would like to verify above readings on a know speaker.
Thanks
Bob T
Hi Bob
Model 50 and 51 used speaker "P" - field coil 1140 ohms.
Model 80 used speaker P-5 (early production) or P-6 (later production) - field coil 1140 ohms.
Yes, you can substitute one for the other as both have the same ratings.
Hi Ron
Thank You, that is good news as yes that was my intent .
I have a 551 someone put a 2500 Ohm Coil Speaker in.
Merry Christmas
Bob T
