I'm working on a 37-600 and noted that each tube socket has p1 grounded to chassis. Is this supposed to have metal tubes?
No, but I guess Philco wasn't taking any chances...in case someone installed metal tubes later on for some reason...
Philco refused to install metal tubes in their sets as shipped from the factory - part of their ongoing feud with RCA.
Fun little sets those '600. Worked on a few myself.
Great thanks, Ron. This set has a lot of whistles where I think stations would be. I still need to do the alignment. The alignment steps on this one are the strangest I've seen. Any advice would be appreciated.
The speaker table error?
Philco 70 antenna lead
There are currently 3302 online users. [Complete List]
» 3 Member(s) | 3299 Guest(s)
