Philco 87 cap question
Take a look at this photo. I'm sure this view is familiar to someone. You see those caps coming off of those two coils? The third one (to the left of those two) has been removed by the last guy. Since a replacement would be easy enough, (1) Was there a reason to do this? and (2) Since the radio seems to work fine, do I leave well enough alone? And (3) the two remaining are paper caps, .1, with a resistor, 100 ohm, inside and should they be replaced? (The chassis has been recapped.)
[Image: http://i191.photobucket.com/albums/z309/...79fc0d.jpg]
http://www.philcoradio.com/tech/images/87.jpg
The reason probably was the capacitor either leaking grossly or shorting.
It is desirable to replace it as it is a decoupling cap, but it will work without it.
Now as to should you replace the other two....I would, as again, they are decoupling caps and are exposed to the raw power voltage, so if they go, they will possibly take something in the power supply (choke, field coil) with them.
Or you could try your luck.
Were they RC filter caps I'd say "if the radio works well, leave them", but in case of decouplers I am pro-active.
Thanks.....is that 100 ohm resistor, part of these caps, anything special?
Those decouple the RF to prevent oscillation. On my 87 all where leaking badly. What I did was cut the ground wire off of the old cap and solder in a replacement from the top lug and the other to ground. The new caps are small enough to hide under the old ones.
Good playing set when it's all fixed up!
I followed your instructions and it worked perfectly. The radio sounds great. Thanks.
I just restored a very similar radio (Philco 86) and it
had the same decoupling R-C networks (qty 3).
I chose to be pro-active and replace all three. I actually
removed them and replaced them with modern
100 Ohm resistors and modern 0.1 uF caps.
I saved the originals. Some day I may see if I can
clean out the center part where the old cap is and
replace it with a new cap. That would be the
best way to preserve the original "look".
Herb S.
Ithaca NY
91H Code 126 Restore
Hi Nick, I am finishing up a 91 code 121 (one speaker). The dashed line is for the code 221 (2 speaker) set. I see there...dconant — 11:17 AM
Joseph, Yes, Rich is right, they are just fine to be left in there. Also, what I do when I re-stuff these specific o...morzh — 09:41 AM
Hello Joseph, I would leave them they are just fine ! Man Moyer Electronics brings back old memories I did not know th...radiorich — 09:33 AM
Rich Those are exact same I used before. I just recently bought these from Mouser. DE2E3SA103MN7AT02F It is exac...morzh — 09:16 AM
Morning, Ron! Yep, that’s the Moyer I spoke with. They did say that they researched for any off-brand equivalents but di...jrblasde — 08:51 AM
Joseph, the Moyer Electronics I’m familiar with is in Pottsville, PA. Only a half hour from me. My dad used to to buy fr...462ron — 08:24 AM
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
There are currently 3557 online users. [Complete List]
» 3 Member(s) | 3554 Guest(s)
