Need a clean schematic for Philco 42-380
Hello:
I'm looking for a clean copy of a schematic for a 42-380. Nostalgia air offers a copy, but it's hard to read. The Rider's copy is also hard to read. Any online source for a clean copy. Thanks.
You can find one here: http://www.audiophool.com/Philco.html . You'll need to download the DjVu reader but that's easy from here http://djvu.org/resources/
Chuck Schwark has the best there is. He only deals through the mail, and doesn't do PayPal, but his work is great. Nice big, clear schematics and they come with all service literature and updates.
There are currently 9787 online users. [Complete List]
» 1 Member(s) | 9786 Guest(s)
