Threads: 103
City: Calgary, AB, CA
(This post was last modified: 01-03-2014, 06:35 PM by Dan Walker.)
Threads: 27
City: Rochester, NY
Looks good Dan. Looks like she'll clean up nice.
Regards,
Tim
Threads: 2
City: Renton, Wa
Yes looks good,I like that cabinet--
Threads: 92
City: Clayton, NC
I like it too! Great Job, Dan! ![Icon_thumbup Icon_thumbup](https://philcoradio.com/phorum/images/smilies/icon_thumbup.gif)
Threads: 16
City: Kokomo, IN
Nice set it has variable if band with just like my Sparton 1466.
Threads: 92
City: Clayton, NC
Interesting. All three IF cans are variable. Also has the 42s driven by two 6C5s. Wonder why they did not use the 6F6, which is octal like the rest of the set (minus the viso-glo) and electically the same as the 42.
Threads: 31
City: Lapeer
State, Province, Country: MI
Nice radio. The chassis is neat, clean and orderly. I hate when everything is crammed together. Is the switch for the MP3? Joe
Joe
Threads: 103
I added the switch to the radio . It is a for the phono input and
of course you can play the MP3 through it [with the proper adapter]
There was a lot of room under there but the hard cap was the one under the band switch.
With the help of a member of another forum I got everything going and can't wait to do the cabinet
Threads: 97
City: Poughkeepsie, N.Y.
Wow that radio seems simalar to my Grunow console that I have.... Did both companies make the same radio?
Threads: 97
Good luck restoring that radio, I very much like the style of the cabinet.
Threads: 103
(This post was last modified: 02-27-2014, 02:16 AM by Dan Walker.)
Threads: 103
Here is what I have done so far.
Threads: 27
City: Petaluma, CA
Now that's a far cry from your original pictures! Your careful attention to this cabinet surely accentuates it's fine lines and varying wood shades. Keep the pictures coming!
Craig R.
Threads: 103
Threads: 562
This looks stunning. Yammie!
Quick progress report:
Hi Rod,
Hello Tim,
