RESISTOR ID 38-15 philco help
Just join have been fellowing your work on the 38-15, found one at a flea market about 4 weeks ago. Most of my questions have been answered before being asked. My radio does not match the sch, I have replaced caps and out of spec resistors but have not changed the circuits as installed. Sure is a nice playing radio using about 8 feet of wire for ant. David
