Radio Gallery?
Kia Ora (greetings from New Zealand) I was wondering if this site has a gallery for Philco radios available in New Zealand? I have two such examples & am happy to offer jpegs for display on this site. My avatar is the dial glass of one such radio which I re-drew in Corel.
Welcome to the Phorum! There is a spot on the site the has a brief mention of New Zealand sets, http://www.philcoradio.com/world/other.htm . I imagine Ron, the site owner will comment but you can contact him with the info found here http://www.philcoradio.com/contact.htm
6A8G - welcome! I would be honored to place photos of your NZ Philcos on the site. Contact me via PM for more details, unless you've already contacted me via email (I see I have an email waiting from someone in NZ, maybe you?).
