Capacitor replacement kit
Mike,
You've emptied your sent items and trash as well?
No.
Let me do it.
Thanks.
ThAnks it worked.
Glad to be of service!
Philco 91 Tuning Condenser
There are currently 9092 online users. [Complete List]
» 3 Member(s) | 9089 Guest(s)
