Beam of Light
Does anyone have a Beam of light record player? I have one but near as I can tell it is missing a part the controls or sets the turntable speed. If you have one could you take a closeup picture of the end where the governor is? Mine has a hole in the bracket and it looks like there should be something there to hold the end of the governor.
Other than the speed problem I have it playing good.
Thanks for any help you can provide.
Gregb
hey Greg
what model do you have
sam
The radio is a 41-608, I would have to look to see if there is a model number on the record player.
Gregb
I've got one, but I think it's missing something there, too.
I'll try to dig it out this weekend and take pics anyway.
PM me if I forget. I can't begin to say how busy I am recently, but I'll be happy to help.
I have the 41-608 with the correct changer. I am also working on another of the same changer over the weekend. Pm me and I will take a look at it. My changer has perfect speed, but after it cycles and starts to play the record, the tone arm abruptly shifts back to the right, which I cannot seem to stop. Does yours do that?
David, I am not to the point where I can see if the cycle works properly or not. Sad to say I have so many projects at the moment that I am not sure when I will get back to the BOL. Truth be told I have owned it for 15 years and so far havent spent more than an hour working on it.
Gregb
Philco 91 Tuning Condenser
There are currently 10012 online users. [Complete List]
» 1 Member(s) | 10011 Guest(s)
