New Flea Market found and Philcos!
I agree they possibly could have re-located it, but affordable places for businesses like that are at a premium around here. Usually older structures are cheaper around here, but then remember most of those have been demolished to create more parking and vacant lots. Basically, I can't recall any places being available in the area for that market to have moved to when they finally closed last year. Ironically, late last year several places finally opened up, but have been quickly filled up again.
Most of the flea markets here operate in a parking lot over a weekend, usually on a Sunday, so they don't even need an indoor space. Many of the indoor ones I have gone to operate in a similar fashion, like in the drill hall of an old armory or empty store space in an strip mall.
Most of the flea markets around here only sell cheap T-Shirts, tube socks that fall apart and off brand detergent.
